If this belongs under the DosExecPgm topic, I apologize. I've also started a thread on the InstallShield ISPro6.x community forum, but have had no responses after a few days. This problem is holding up a release, so I'm in the hot seat right now.
Occasionally, we've had customers say that they get an error 80040707 ISRT._WaitOnDialog when the IS Install Welcome Dialog is being posted. Until now we've been unable to isolate it.
We've narrowed it down to this:
- Windows XP or 2003 only (other Microsoft operating systems are okay).
- Regional Settings set for more than one language. Doesn't matter which one is active.
Our setup is built w/ISPro 6.31, and is English only. Setting Regional Settings for English US and English Zimbabwe (for example), leaving US as the defeault (or not) will cause the problem - every time. Removing the second language fixes the problem every time.
I would guess that this means we need the multi-language support, except that this works fine on Windows 2000. Adding multi-language support isn't an option right now either, since we have many custom dialogs/strings which would need translation and we are in the process of converting to IS Dev 8 MSI packages.
Thanks much for any help you can give.
exception 80040707 on win2003/xp only
Bill Stephens
, May 23 2003 15:53
Posted 23 May 2003 - 16:32
Clarification:
When I said "Setting Regional Settings for English US and English Zimbabwe..." I should have said setting the Regional Options -- Standards and formats, not Languages. Adding the Zimbabwe format but not changing the active format from US, will cause the problem.
Posted 23 May 2003 - 20:49
Never mind. My apologies.
I've narrowed it down even further and determined it has something to do with one of my own DLLs.
