I am trying to run a silent install. I have recorded my response file. However, when I run in silent mode, the log file shows a ResultCode -12 which says that "Dialog boxes are out of order". Any ideas on why this is happening?
Silent Install
Steve Rauda
, Apr 11 2001 16:50
Posted 12 April 2001 - 13:37
I have found in the past that silent installs must be recorded exactly as they will be installed. It is likely that you have another dialog box or something showing up that was not on the original recorded install. Run the install on the new machine to see what all is comming up and verify with the iss file.
