Adding Maintenance to current project
Posted 04 February 2002 - 21:05
Posted 05 February 2002 - 00:33
"It is not hard to alter the program block to event driven; at least since you sound like you already have the file groups destinationed (components were where the destination was in 5.5) and I would assume it compiles. So, all you really have to do is find the componentmovedata. Everthing before this goes in onfirstuibefore and everything after goes in onfirstuiafter (basically). Throw away the componentmovedata as it is done automatically after onfirstuibefore (and onmaintuibefore). I'd make a copy of the script file before starting. I bet then all your event functions get hit correctly. (I hate to be a pesimist but I have never seen the program block work correctly in 6.x and only read about problems from this.) "
SOURCE: http://www.installsi...rum1....<p>Hope it helps.
Posted 05 February 2002 - 20:59
Posted 05 February 2002 - 22:38
What I have so far is when the user selects 'modify' from the SdWelcomeMaint dialog, it will go directly to SdComponentTree function and display all of the components available. I want to limit what they can select from and how many components they can choose. I can create my own dialog to get the selections, but how do I set that selection in my script.
Thanks in advance
Posted 06 February 2002 - 04:20
If I understand your correctly, you want to know how to actually apply the selections from your custom dialog should you choose to go that route. If that's the case, you'd use ComponentSelectItem to do just that.
Now other people have had similar questions as yours and can be found at the following post:
http://www.installsi...rum1....unately there also aren't many good answers there. Just some workarounds.
Posted 12 March 2002 - 15:25
Jennifer
