I got a Standard project on Installshield Developer 7. I am using a compressed release, and my problem is that i cant find the path to the directory where the setup.exe is located. SRCDIR gives me the path to a temp-folder where it is uncompressed. I've done a lot of searching, and MsiGetProperty seems to be the answer, but how can I use it, and can I use it in a standard project? I do know that by using an uncompressed project, this problem is omitted, but I need a compressed one.
The reason why i need the setup.exe directory is that my installation somethimes require a very large file, and I dont want to include it in the setupfile itself, i want it to look for it in the same directory.
http://support.insta...ticleid=Q105487
This is the link where I got the tip avout MsiGetProperty.
I am very uncertain about what to write in hMSI argument...
Any help would be apreciated.
Hanssen
MsiGetProperty
hanssen
, Jun 27 2006 13:26
Posted 28 June 2006 - 08:07
MsiGetProperty won't help. The msi runs from the temp folder.
The system variable SETUPEXEDIR is what you need, but I don't think it existed in version 7 but was added in a later version.
Posted 29 June 2006 - 08:53
I ment that i could get the SETUPEXEDIR variable by using MsiGetProperty, but i see now that I did not even mention SETUPEXEDIR. So there is no way I can get that directory, unless i dont compress the project...(?)
Posted 01 July 2006 - 10:15
You can use SETUPEXEDIR directly in your script, no need for MsiGetProperty. But only if SETUPEXEDIR exists in your verison of InstallShield. I'm not sure if it existed in Developer 7 or was added in a later version.
