I want to incorporate the silent install of another product along with mine.
The problem is the other setup requires lots of options changing during setup. I believe I can specify these on the command line using msiexec.
But how do I find out exactly what options are available to me (i.e. the variable names etc.) without having access to the original script?
Silent install of another product
chaosss
, Aug 16 2006 11:40
Posted 16 August 2006 - 12:49
You can open the msi file in Orca or some other MSI editor to see the property names that are associated to checkboxes, editboxes etc. Or you generate a verbose log to see the properties and their values so you know which properties to set on the command line. Or you use a tool (like InstalLShield) that can do this for you, generating a "response transform".
Posted 18 August 2006 - 08:09
About combobox, how can I select the good parameters in /quiet mode?
I have 2 combobox in my installation but I can't initialise it well
setup /L1033 /V" /quiet USERNAME=\"TESTDAVE\" COMPANYNAME=\"GDBIDave\" INSTALLED_HICAD=\"c:\EGR\" HICAD_OC_DIR=\"c:\EGR\" HICADDIR=\"c:\EGR\" HICAD=\"c:\EGR\" CURRENCY=\"GBP\" TAX=\"0.21\" INSTALLDIR=\"c:\EGR\"" |
TAX and CURRENCY are the both combobox and the the value is the same of field Value in Orca.
Do I need to use another? like Order or Text?
