Im trying to retrieve a dword from the registry and then displaying this in a dialog box.
However, it always puts a # infront of the value. How can I get rid of this?
I am using DevStudio9 and Basic MSI project.
Help,
DWORD In Reg returns with #
mouy
, Feb 13 2004 06:28
Posted 13 February 2004 - 10:17
You will have to use a custom action to remove the leading #
Posted 04 November 2004 - 00:19
is there a way to do a compare against this value?
i'm reading in a DWORD registry value and would like to use this value in a conditional check. do i have to remove the leading '#' or is there some way to do a comparison with this value without having to write a custom action.
Don Tasanasanta[br]Configuration/Installation Eng
Posted 04 November 2004 - 14:24
That depends on your comparison. You could compare against "#1234" for instance.
Posted 04 November 2004 - 23:01
wow... that actually worked. who would have thunk it.
thanks!
thanks!
Edited by dtasanas, 04 November 2004 - 23:01.
