Can anyone please help me with the following problem?
Issue: I'm using Installshield v5.5 to create a setup routine, I have created two shortcuts for this routine one in START > PROGRAMS and the other on the DESKTOP.
Problem: I have declared a global variable (gvProgRootDir) in the setup.rul script. This variable is populated with the value of an AskPath function, which in my case is D:\91b\. However when I add gvProgRootDir to the target of the shortcut's it doesn't pick up the value D:\91b\ as required, it enters C:\ as the default. Below is an example of the target for both shortcuts:
<gvProgRootDir>\bin\prowin32.exe
Question: Can anyone tell me why the target is picking up C:\ instead of D:\91b\ as required?
All help is greatly appreciated, thanks in advance.
