How do I embed an mst file into an msi file. Thanks
Embedding an MST file into an MSI file
soccernut
, Oct 23 2002 19:46
Posted 24 October 2002 - 16:31
using the installshield adminstudio you would launch Author ( "Author & Enhance Setups" ). from the "Tools" pull-down menu select the "Create/Apply Transform" item. from here select the "Apply a Transform" radio button. Select your transform and save it in the NEW msi.
when you want to specify this transform at install time pre-fix the transform name with a colon, ":".
now how do we do it with the msi sdk tools or wise ?
