I have an app that is installed using setup.exe. It shows up in the ARP and I can add info to SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall.
There is a "support information" under ARP with "repear" button.
How can I make use of the "repair" button, it is currently not functioning.
I'd like to rerun the entire "setup.exe" when "repair" is initiated.
ARP Support Info
butik
, Oct 06 2005 01:01
Posted 06 October 2005 - 12:05
The Repair button will re-run the .msi file, not the self-extracting setup.exe. Therefore you should leave the extracted .msi file on the target system.
Otherwise you could try to set ARPSYSTEMCOMPONENT so that Windows Installer will not write an Add/Remove entry, and then add all the reuqired entries in the Uninstall key of the registry yourself.
Posted 06 October 2005 - 12:26
Stefan, what entries should I add to uninstall key to make use of the "repair" button?
There is UninstallPath and ModifyPath, neither do the trick.
Posted 06 October 2005 - 14:22
I'm not sure (don't even know if it's possible). Look at other existing entries, or search MSDN.
