SCRRUN.DLL randomly registers when my program is installed. Doesn't appear to be op system related. I have tried every way to load this component. Using REGSVR32 manually makes my program work correctly every time. Can anyone show me how to do a CA to do this. I know NOTHING about custom actions, so you have to do this step by step.
Need to register a dll
pdrogers
, Mar 02 2002 00:29
Posted 06 March 2002 - 05:07
Are you sure you've set up your installation to register the DLL?
* Make sure you have set the component to extract COM data at build-time.
* If you right-click the DLL in the file list and hit properties, you'll see a checkbox for Self Register. Clicking this makes InstallShield add some custom actions which run regsvr32 on the DLL. This should only be used in the COM extraction fails.
Jamie
The geek shall inherit the earth
