Hi
Im using my InstallShield Project to generate an installer that let me create a database, in my installer I have a Standar Dialog named SQLServerSelectLoginDlg, what I need is take the information that the user put in that Dialog (DataBase Server, User and password) for it I use the CtrlGetText function, first i search the name of my Dialog and the Id of the control where the user put the information in the Dialogs View, I think that the information in that window is rigth but now when I want to see it I can´t because this function don´t let me show anything, I use it in that way:
CtrlGetText ('SQLServerSelectLoginDlg',305,svText);
and it doesn´t work, the i use it in that way:
CtrlGetText ('DialogId_10109',305,svText);
and it doesn´t work either.
What is the problem?? Can I do it in another way??
CtrlGetText
arandasoft
, Apr 26 2005 17:53
Posted 26 April 2005 - 18:34
#define EDIT_USERNAME 1205 // ID in your dialog of some control here it's edit // box #define SD_DLG_USER "UserCheck"; // Name of dialog in ur IDE -> "Dialogs" szDlg = SD_DLG_USER; // It's just for aesthetics CtrlGetText( szDlg, EDIT_USERNAME, svUserName ); // svUserName it variable //that contains your text |
Is this ok ? or more detailed needed?
Bonum initium est dimidium facti
Posted 26 April 2005 - 18:56
I tried with your code and anyway it doesn´t work...
look this, it didn´t show me nothing...
#define EDIT_USERNAME 305
#define SD_DLG_USER "SQLServerSelectLoginDlg";
function OnMoveData()
STRING szDlg,svUserName;
begin
MessageBox( svUserName, INFORMATION ); //that contains your text
end;
begin
end;
Posted 27 April 2005 - 07:24
You need to call this while the dialog is on the screen, i.e. inside the dialog handler function.
