Is there any to avoid the nested directory structure that is created when using "ISBUILD"? I don't want the directories, "Disk Images", and "Disk1" created when I am doing automated builds.
Automated Build using ISBUILD
rajkulkarni
, Sep 16 2004 20:47
Posted 17 September 2004 - 01:22
I've not used the ISBUILD functionality before, but you could try changing your media to call a batch file afterwards to move the files to the desired location.
Posted 17 September 2004 - 14:43
we do such automated builds with is5.1.
you can use a link to a temporary folder instead of all the file links is5 needs
start some batch file, that copies all files needed into this temp dir, then make sure you have set the INCLUDE variable for rul und h files, run "compile." to do a fresh compile of the seupt script, start "isbuild" with parameters -m"%media name%" -p"%path to project%" and -b"%target folder", you can use >> isbuild.rpt to generate a report.
added: before using isbuild, we had to run many setup builds with little variation ... now we start one batch file, that runs all the setup builds. none of them is forgotten anymore, all are sorted into a target folder structure ... with one click
Edited by Perotin, 17 September 2004 - 14:48.
Gruß / regards
Thomas
Thomas
Posted 17 September 2004 - 15:01
Not 100% sure about this, but I think I saw a "Enable shallow folder structure" flag in Installshield Developer 7, maybe there is such a flag in your release too?
