Is there a way to determine INSTALLDIR on run time? from an ini file, for instance, or by checking files that are going to be installed.
Thanks.
Changing INSTALLDIR on run time
Artyom
, Sep 06 2006 07:08
Posted 06 September 2006 - 08:19
You can use a custom action with the MSISetProperty funtion and set the INSTALLDIR at runtime. If you can read the INSTALLDIR e.g. from the registry you can use the AppSearch and RegLocator tables to set the INSTALLDIR to a specific value.
Barbara
Barbara
The difference between theory and practice is larger in practice than in the theory.
