How to include sub folders
Posted 09 January 2002 - 20:10
How to implement this feature.
Ganapathi.
Posted 09 January 2002 - 20:33
Can you be more explicative. I am not sure what you mean by add only the root folder. Are you trying to create Components with Dynamic Links?
Kurt Schneider
Posted 09 January 2002 - 20:41
Gana
Posted 09 January 2002 - 20:55
If you are trying to create a component which contains all files in a Folder not including Subfolders do the following:
1. Go to the Setup Design view
2. Create a Feature (if you already haven't)
3. Create a Component (if you already haven't)
4. Under the component in the tree view click on "Files"
5. Click on "File Linking"
6. In the white space under Link Type, right -click and choose New Dynamic Link.
7. This will present you with the "Dynamic File Link Settings" dialog box.
This dialog will give you the option to include the whole folder with or without subfolders and a few other options.
Hope this Helps
Kurt Schneider
Posted 09 January 2002 - 21:13
I do n't use any tools(Install shield),I just use Microsoft SDK .
Do u know any workaround in microsoft tools.
thanks,
gana.
