1) Make an standard install where the main executable you're installing has a long file name (like "SuperSetup.exe")
2) install to 98se
3) Apply a patch that updates the main executable (and also some support files in my case)
Applying the patch causes the executable name to be reduced to 8.3 format thereby breaking all the shortcuts to it.
If you apply the patch again, you end up with 2 versions of the executable - one with a long file name and one in 8.3 format.
This happens in 98se and ME, but not 2k.
Anyone else seen this?
