I have a custom action which uses InstallScript to set a property (property is used to set an install path to some components). By default this property has "NotFound" a value. When I install/uninstall from .msi everything works fine, but when I try to uninstall from Add/Remove Programs message: "Error 1606. Could not access network location NotFound" appears. Could you comment on the above and suggest any solutions.
Custom Action not working when uninstaling from add/remove
Dri
, Feb 13 2001 11:18
