Our IS Dev 7.02 installer hangs when installing on WinNT4 or W2000 systems using a Citrix Metaframe Server. The dialog portion of the installer works fine. The installer hangs at 0% when the file install process begins.
I have /verbose mode .log files from these hung installs. The log file shows the install setup files were executed, but the file ends at the point where the first "===Verbose logging stopped" would appear.
The user is logged on as Administrator.
We have manually installed isscritp.msi which installs fine, but our installer still hangs at the same point.
Any ideas?
Install hangs on Citrix Systems
bobv
, Sep 05 2002 16:48
Posted 12 November 2003 - 17:08
Installing via a session does not seem to work, but I've had no problems installing directly on the server.
Copying the installer to the server and then activating it via the session seems to work okay
Edited by Ailz, 12 November 2003 - 17:13.
Posted 12 November 2003 - 18:04
I am NOT positive about this, but I have heard that installing to terminal server causes all custom actions to run in system context. I suppose the same could happen with Citrix.
