Hi all,
I have the following problem:
When some of installed files are running and I try to uninstall the Files in use dialog shows up but is empty.
How to know what are the files which must be closed?
Or how to fill the list
I am using Standard Project in IS Pro 7.1
Files in use on uninstall
bababyt
, Nov 24 2004 14:18
Posted 01 December 2004 - 18:51
Check your OnFileLocked() it should look like this
function OnFileLocked(szFile) begin return SdExceptions(LOCKED, szFile); end; |
if not, make it so. If it does look like that then your probably getting an empty string for the file that's locked. If that's the case I would set up a log file to check once I see that msg box. That should give you an idea of what file is being removed before this occurs.
