Would like to know if there are any examples of how to extract a file within an MSI file given the file name only.
Obviously, this file extraction is independent of the actual msi installation launch itself.
Any help is appreciated. Thanks.
Programmatic File Extraction
blah blah blah
, Aug 07 2003 15:40
Posted 12 August 2003 - 12:41
The problem is that you will have to determine whether or no the file is stored in the binary stream of the msi, or in a .cab file, extrenal to the msi.
Once you have this information, you should be able to just either extract the file from the binary stream, or open the cab file and grab the file out.
this is pretty complicated.
What do you need to achieve?
