Hi to all,
I used to call setup.exe within a DOS batch file passing some parameters.
Inside setup I extracted them using:
StrGetTokens (listParameter, CMDLINE, " ");
Well, I'd like to package that setup into a self-extracting executable but I discovered that way doesn't work!
If I choose to package the setup into a self-extracting executable file with the Media wizard help I notice there is a setup command line parameters line to fill, but at build time I don't know the parameters, that's because I choose to start setup by a DOS batch file...
Are there others way to pass parameters to a self-extracting executable?
Thanks to all,
ciao Giuseppe
Passing parameters to a self-extracting executable
gronchi
, Apr 03 2003 14:58
Posted 03 April 2003 - 16:35
To pass other parameters to the setup contained with a self-extracting excutable, use -a followed by your normal argument list. The 'a' means additional.
Posted 16 April 2003 - 14:41
| QUOTE (TacoBell00 @ 2003-04-03 15:35) |
| To pass other parameters to the setup contained with a self-extracting excutable, use -a followed by your normal argument list. The 'a' means additional. |
Thanks, it was very simple but I can't reach it by myself!
Posted 16 April 2003 - 15:19
| QUOTE (gronchi @ 2003-04-16 09:41) | ||
Thanks, it was very simple but I can't reach it by myself! |
I think you mean that you couldn't "figure it out" by yourself.
Posted 17 April 2003 - 07:17
| I couldn't "figure it out" by myself I can't reach it by myself |
Aren't these two phrases the same?
If not, I apologize for my bad english...
