The problem is that if I run the installer on a system that had the product installed with the 6.12 version of the installer, it wont recognize the old installation and will try to do a clean install instead of a modify install.
I have changed product code, package code AND the upgrade code to all be the GUID from the uninstall Setup in the hidden "InstallShield Installation Information" folder. None of then do the trick.
Any suggestions?
