I'm having an issue with an edit box in an InstallScript dialog - IS 2012 Spring - I've got an edit box with Multiline set to "True".
When I call CtrlGetMLEText and get a stringlist back, I find that the reading is missing some characters from my string.
The string pasted into the dialog is about 1200 characters, with unpredictable line breaks (in many cases none, as the value is usually pasted from an email).
What I'm noticing is that when I pull the value out of the edit box and echo out the lines so I can see what's being pulled, I notice it's missing characters (as few as 2 missing to as many as 15 characters will be missing)
This is the code I've got pulling the edit box in:
