I'm using InstallShield Developer 7.0 SP 4.
During the installation process I need to execute another 3rd party installer which will not allow another installer to be active at the same time.
To work around this problem, I execute a small launcher which waits for my installer to exit, and then launches the 3rd party installer.
I have 2 situations which can occur:
- the 3rd party installer may cause a reboot.
- the 3rd party installer returns control back to the launcher
Here's my question:
How do I determine where my original setup.exe (it is downloaded and could be placed anywhere) was executed from?
This way I could set a registry entry for runonce if the reboot occurs, or I can restart the installer if there wasn't a reboot.
How do determine where setup.exe is?
cowboy3398
, Sep 13 2005 18:59
Posted 13 September 2005 - 23:34
This information was cut/paste from here:
http://www.installsh...SetupExeDir.asp
// global variable to store SETUPEXEDIR property value
STRING SETUPEXEDIR[MAX_PATH + 1];
function OnBegin( )
NUMBER nBuffer; // local buffer-size variable
begin
if (!MAINTENANCE) then // available only during a first-time installation
nBuffer = MAX_PATH + 1; // initialize size buffer before calling MsiGetProperty
MsiGetProperty(ISMSI_HANDLE, "SETUPEXEDIR", SETUPEXEDIR, nBuffer);
// for testing: display the variable's value
MessageBox("SETUPEXEDIR = " + SETUPEXEDIR, INFORMATION);
endif;
end;
Because the variable SETUPEXEDIR is a global variable, you can use its value in any later event-handler function.
