I use InstallShield Developer 8 Basic Project to bundle IBM JDK\JRE with our package. I need to put IBM Java Plug-in icon in "Control Panel" not "Add or remove program". Please advise how to do it.
Meei-Ing Sun
Java Plug-in
misun
, Sep 07 2004 22:16
Posted 08 September 2004 - 08:24
I assume you run the Java setup as sub-install or custom action, and I assume this Java setup creates that icon. In this case (unless you created the Java setup) there's no direct way to do this, and in my opinion you shouldn't modify the default behaviour.
The only option I can think of would be:
- delete the Uninstall registry entry to remove it from Add/Remove Programs list
- create a control panel applet for Java and install it
