MDAC 2.7 not being installed from MM
Posted 12 January 2004 - 19:33
If anyone has any ideas why this might be happening please let me know.
Jennifer
Posted 13 January 2004 - 09:11
Posted 13 January 2004 - 21:55
Posted 14 January 2004 - 09:19
Is this a fresh install or are you installing an update?
Posted 14 January 2004 - 21:04
MSI (s) (30:D0): Component: MDAC27.C9C35FC7_5AEE_4C1E_8BD2_80ED9FA87FFF; Installed: Absent; Request: Local; Action: Local
MSI (s) (30:D0): Component: __MDAC27.C9C35FC7_5AEE_4C1E_8BD2_80ED9FA8765; Installed: Null; Request: Local; Action: Local
MSI (s) (30:D0): Component: __MDAC27.C9C35FC7_5AEE_4C1E_8BD2_80ED9FA8766; Installed: Null; Request: Local; Action: Local
Action start 10:56:50: CheckForMDACInstall.C9C35FC7_5AEE_4C1E_8BD2_80ED9FA87FFF.
MSI (s) (30:D0): Creating MSIHANDLE (161) of type 790542 for thread 976
MSI (s) (30:D0): Creating MSIHANDLE (162) of type 0 for thread 976
MSI (s) (30:D0): Closing MSIHANDLE (162) of type 0 for thread 976
MSI (s) (30:D0): Closing MSIHANDLE (161) of type 790542 for thread 976
Action ended 10:56:50: CheckForMDACInstall.C9C35FC7_5AEE_4C1E_8BD2_80ED9FA87FFF. Return value 0.
MSI (s) (30:D0): Skipping action: DisplayErrorMessage.C9C35FC7_5AEE_4C1E_8BD2_80ED9FA87FFF (condition is false)
MSI (s) (30:D0): Skipping action: InstallMDAC.C9C35FC7_5AEE_4C1E_8BD2_80ED9FA87FFF (condition is false)
MSI (s) (30:D0): Skipping action: MDAC_RebootAtEnd.C9C35FC7_5AEE_4C1E_8BD2_80ED9FA87FFF (condition is false)
The version of MDAC that is installed on this machine is 2.53.
Posted 14 January 2004 - 22:42
Posted 15 January 2004 - 08:22
Posted 15 January 2004 - 22:03
I have contacted InstallShield support. Their answer was that the setup was determining that MDAC does not need to be updated even though the current version is 2.53. They suggested that I just run the MDAC install manually from the setup. Not much help.
Posted 16 January 2004 - 17:43
Posted 16 January 2004 - 20:43
Condition: ($MDAC27.C9C35FC7_5AEE_4C1E_8BD2_80ED9FA87FFF = 3) AND (INSTALL_MDAC=1)
From the ModuleInstallExecuteSequence
Posted 17 January 2004 - 09:07
Posted 25 May 2004 - 20:31
Can I write condition where compare different version MDAC, and if MDAC in merge module was early - install that package.
I insert Merge Module Custom Action, before InstallWelcome.
Posted 27 May 2004 - 11:31
Why $MDAC27.C9C35FC7_5AEE_4C1E_8BD2_80ED9FA87FFF = 3. What mean this value? |
This means that the custom action should run only if the component named MDAC27.<Merge Module GUID> is selected for installation. This is used to make sure the MDAC install only runs if the feature associated with the merge module is selected for installation.
| Can I write condition where compare different version MDAC, and if MDAC in merge module was early - install that package. |
I believe the merge module does this internally in another custom action and sets the INSTALL_MDAC property accordingly. You could modify the merge module to use another (or additional) property that you set based on a system search.
Posted 24 November 2004 - 16:17
Hi (My first message here Sweet
I had exactly the same problem but after some research I found a solution. I used the MDAC27ENU.msm (version 2.71.9040.2 from InstallShields download page) but it didn’t install MDAC. I found that in the MergeModule is a VBscript called Check and in that script is a property called MDAC27_SETUP_VER used but there is no property called this in the Merge Module. So the solution is to add a property MDAC27_SETUP_VER with the value 2.71.9040.2 to your installation then it works fine. I think this is a bug in the SP1 version of the MDAC MergeModule because the old MSM (version 2.70.9001.0) don’t use the property MDAC27_SETUP_VER but MDAC_SETUP_VER.
/Sillen
Posted 24 June 2005 - 16:27
Seems odd that you'd want to specify it on the command line or set it in the MSM itself?
