hi,
I'm using a standard project. I want to check to see if a feature is installed previously when I am re-installing..
What's the best way to do that ?
thanks
Best way to check a feature's installed state ?
TreviBoy
, Jul 01 2002 21:43
Posted 07 August 2002 - 21:30
/* these are the enumerated install states returned by MsiGetFeatureState
-6 INSTALLSTATE_BADCONFIG //The configuration data is corrupt.
-5 INSTALLSTATE_INCOMPLETE //The installation is suspended or in progress.
-4 INSTALLSTATE_SOURCEABSENT //The feature must run from source, and the source is unavailable.
-3 INSTALLSTATE_MOREDATA //The return buffer is full.
-2 INSTALLSTATE_INVALIDARG //An invalid parameter was passed to the function.
-1 INSTALLSTATE_UNKNOWN //An unrecognized product or feature was specified.
0 INSTALLSTATE_BROKEN //The feature is broken.
1 INSTALLSTATE_ADVERTISED //advertised feature
2 INSTALLSTATE_ABSENT //The feature was uninstalled.
3 INSTALLSTATE_LOCAL //The feature was installed on the local drive.
4 INSTALLSTATE_SOURCE //The feature must run from source, CD-ROM, or network.
5 INSTALLSTATE_DEFAULT //The feature will be installed in the default location: local or source.
