I am using the sample embedded ui provided in DTF.
I have a embedded chainer exe which installs all the msis.. and i am using the sample embedded ui to show the progress..
I have a question in that... I do a MsiEndTransaction Commit at the end of the code in the chainer exe "MsiEndTransaction(MsiTransactionState.MSITRANSACTIONSTATE_COMMIT);"
The problem is that this line in the code gets called only after i close/exit the sample embedded ui. Basically this function waits till the embeddedui is closed to execute.. Why does this happen? Becos I wanted to show commit progress too in the ui at the end...
is there a solution for this?
Hari
Sample embedded UI in DTF problem
haripanicker
, Mar 05 2009 00:30
