Hi
- Can InstallShield tell the system is running as Terminal Server?
- On a system that is running Terminal Services, each user has a unique Windows directory which seems to be the issue for us to install the s/w.
Dependent software requires files to be installed in Windows directory (say C:\Windows) but "WINDIR" variable returns "C:\Documents and Settings\Administrator\Windows". This misleads the setup putting the files in the wrong directory.
WINDIR when running install on Terminal Server
sod
, Feb 04 2006 03:50
