Hi
i have created a button , when we click on that it will open the open dialog box...and selected file path can get into a variable, but i want to display that path into the text box which is beside that.
I used the CtrlSetText fuction , i used the MsiSetproperty also,but it is not is not working ....
Please give me a solution for this very soon....
Regards,
A.Srinivas
textbox problem
asrinivas
, May 02 2007 05:25
Posted 02 May 2007 - 07:26
You can view this article to solve your problem.
In that example solved some problems that usually appeared with similar tasks in installations.
Posted 02 May 2007 - 11:09
| QUOTE (nesesser @ 2007-05-02 07:26) |
| You can view this article to solve your problem. In that example solved some problems that usually appeared with similar tasks in installations. |
Thanks a lot for your solution...
But there is a problem...i followed the same procedure as given in the document,
bt the selected path is updating in the different text box which is not given by me...
it is not updating into the given property textbox.
Please tell me , what might be the problem.
Regards,
A.Srinivas
Posted 04 May 2007 - 12:58
Then you probably have to adjust the property names.
