i need to create a network share during installation, so i'm trying to use the NetShareAdd function from the Win32 API inside my IScript CA.
This function is prototyped this way in C (from MSDN):
Windows NT/2000 or later: The parameter order is as follows.
NET_API_STATUS NetShareAdd(
LPWSTR servername,
DWORD level,
LPBYTE buf,
LPDWORD parm_err
Windows 95/98/Me: You must specify the size of the information buffer, in bytes, using the cbBuffer parameter. The Windows NT/Windows 2000 parm_err parameter is not available on this platform. Therefore, the parameter list is as follows.
extern API_FUNCTION
NetShareAdd(
const char FAR * pszServer,
short sLevel,
const char FAR * pbBuffer,
unsigned short cbBuffer
My script works for NT/2000, but it fails under Win9X (have tried only win95, but i think its the same in Win98/ME). I think the reason is i'm wrong with the prototyping, coz the setup immediately initiate rollback when i call the SVRAPI.NetShareAdd function. I remember from previous experiences that this could happen when prototype is wrong. But ..... i don't see anything wrong with my prototype, so any help will be very appreciated :))))
This is my Win9x function for the custom action :
prototype LONG SVRAPI.NetShareAdd ( POINTER, LONG, POINTER, LONG );
// windows9x only
#define LM20_NNLEN 12 // LM 2.0 Net name length
#define SHPWLEN 8 // Share password length (bytes)
#defineSHI50F_FULL0x0002
typedef _SHARE_INFO_50
begin
STRING shi50_netname[LM20_NNLEN+1];
CHAR shi50_type;
NUMBERshi50_flags;
LPSTR shi50_remark;
LPSTRshi50_path;
STRING shi50_rw_password[SHPWLEN+1];
STRING shi50_ro_password[SHPWLEN+1];
end;
// W9X only
// share a directory providing szShareName (need _NetShareConnect to be called first)
function _NetShareCreate9x (szShareName, szPath)
STRING szDLL,buff,szPathUpper;
_SHARE_INFO_50 NewShare;
_SHARE_INFO_50 POINTER pNewShare;
POINTER pDirPathNoWide;
LONG res, cbBuffer;
begin
#ifdef __DEBUG__
MessageBox ("in NETSHAREADD_9X",INFORMATION);
#endif
szDLL = WINSYSDIR ^ DLL_NETAPI_9X;
#ifdef __DEBUG__
MessageBox ("szDLL = " + szDLL,INFORMATION);
#endif
res = UseDLL ( szDLL );
if (res < 0) then
MessageBox(ERR_DLL + szDLL, SEVERE);
res = -1;
return res;
endif;
StrRemoveLastSlash (szPath);
StrToUpper (szPathUpper, szPath);
cbBuffer = SizeOf (NewShare);
pNewShare = &NewShare;
pNewShare->shi50_netname = szShareName;
pNewShare->shi50_type = STYPE_DISKTREE;
pNewShare->shi50_flags = SHI50F_FULL;
pNewShare->shi50_remark = NULL;
pDirPathNoWide = &szPathUpper;
pNewShare->shi50_path = pDirPathNoWide;
pNewShare->shi50_rw_password[0] = "\x0"; // No password
pNewShare->shi50_ro_password[0] = "\x0"; // No password
#ifdef __DEBUG__
MessageBox ("Calling SVRAPI.NetShareAdd",INFORMATION);
#endif
res = SVRAPI.NetShareAdd (NULL,50,&NewShare,cbBuffer);
if (res != NERR_Success) then
NumToStr (buff,res);
MessageBox ("NetShareAdd failed. Errorcode = " + buff,SEVERE);
res = -1;
endif;
UnUseDLL ( szDLL );
return res;
end;
The installer rollbacks and exit when i call
same result if i try to prototype it as
prototype STDCALL LONG SVRAPI.NetShareAdd ( POINTER, LONG, POINTER, LONG );
Awaiting for your tips,
Valerio
