When I start the install program created using install shile 6* prof edition,The first dialog box that comes is
"Location to save files".Then the dialog comes witha message "Data1.cab already exist " .Do you want to relace the yes ,yestoall and the other option .Then the OnBigin() function is called .I want to check the version and tell the user that the version existing is new or old ,and if the version existing is old than i want to tell the user to first to uninstall the old verision and install the new version .Can somebody tell how to do this or which is function called before onbegin()
Version check before installing
Ashwin D R
, Nov 27 2001 15:03
Posted 27 November 2001 - 19:38
Why don't you just write a routine at the very first of onbegin?
"I want to check the version and tell the user that the version existing is new or old ,and if the version existing is old than i want to tell the user to first to uninstall the old verision and install the new version ."
OnBegin()
Begin
// basically something like this
if (CheckVersion() <= @CURRENT_VERSION) then
MessageBox("Old version: Uninstall first...
exit;
else
MessageBox("Newer version already installed"
endif;
// rest of your onbegin stuff follows
