All on a sudden I stated to get error 1606.
It waiting for a while in dialog setupinitialization with NEXT & BACK Push butto dissabled. After some time it gives following message.
Error 1606. Could not access network locastion.
However I want to say that I am just testing my setup and al my setup files are in the local machine.
Please let me know what could be the possible solution.
Do I have to do anything in Directory Table or Project Manager table.
Sanjoy
Error 1606 Could Not access Network Location
sanjoygr
, Mar 20 2006 14:28
Posted 20 March 2006 - 21:54
I would just try to recompile your setup first to see if the error goes away.
Posted 21 March 2006 - 05:55
Hi Ghtz,
Even After I recompiled it is not solved.
I had added two labels text on a dialog box to see the values of INSTALLDIR and _BrowseProperty at run time. Then I removed these two text labels.
After that I rebuild my application set up and problem started.
Now I see that have to re-create installshield project once more from the scratch.
I dont know which value in property manager or directory table got changed or is missing.
Sanjoy
Sanjoy
