Hi All
Please bear with me as although I am tech minded by all of this i have learn myself from cut and paste instructions.
I can remove any of our packed MSI's at work as they are all cached on the workstations and seems to work pretty well but i am having more problems removing unauthorized software where the MSI is not on the computer.
best example is of course iTunes!
I am trying to remove the install by running
Having problems uninstalling ref GUID
acreda
, Feb 04 2010 22:20
Posted 04 February 2010 - 22:20
| Misexec /x {3F2504E0-4F89-11D3-9A0C-0305E82C3301} /qb |
of course that is an example GUID but as far as I'm aware this should work ive got the GUID from the registry of the remote PC from the ......./current version/uninstall... is there a switch I am missing? should i take away the space between the /x and {?
just to give you the proper context i am running this from my own workstation, by opening a cmd on the remote pc using psexec, which in turn has been launched from a cmd box running as my AdminID, so i should have good permissions. i can certainly issue install and transform commands this way.
I mean do i need the /a switch? sorry if i am rambling
I did notice in the remote registry that the uninstall path was just MsiExec /I{3F2...... is it possible for apple to stop an msi removeal via msiexec?
thanks for the pain
Bry
Posted 05 February 2010 - 10:12
You shouldn't need the /a switch.
To see why your uninstall isn't working try without /qb and/or generate a log file. Maybe the GUID is not the correct ProductCode or there's something in the package that intentionally prohibits silent uninstall.
Alternatively to msiexec /x {ProductCode} you could use
msiexec /i your.msi REMOVE=ALL
Maybe as a first step try and see if everything works as intended when you're logged on locally on the machine. Once oyu have the correct command and GUID you can try remotely.
