Hi All, i want to add relative path for merge module location in Tools -> option -> merge modules tab , it was written in help file like below
"Enter the paths where you store merge modules (.msm files). Separate additional paths with a comma, as in the following example: C:\MergeModules,C:\My Files\MergeModules
Note that you can use path variables in the path, as in the following
example: <ISProductFolder>\Modules\i386,<ISProjectFolder>\MyCustomModules"
i tried this but it doesn't work , the problem i want to copy and run my project on another machine without any change, but even when i enter an absolute path it doesn't appear on the other machine as it saved on registry as i know.
Edited by Ahmed_Ammar, 09 April 2014 - 17:56.
