I want to install a virtual display driver through DIFx framework.
what is the right way to do this?
Specifically, what should the following field in the INF file be for
this case
DriverPackageType=
This field is mandatory for non-pnp devices whose driver is to be
installed thru DIFX , but i am not sure what is the right value to use
here
any help is appreciated
thanks
Installing Virtual Display Driver thru DIFx
Rustican
, Oct 07 2004 01:02
Posted 07 October 2004 - 17:57
I'm not really familiar with DifX, but there will be a chat on this topic on Tuesday 12 Oct.
Windows Installer Chat: Using the Windows Installer with the Driver Install Frameworks Tools (DIFXApp)
http://www.installsi...msi/webcast.htm
Posted 16 January 2006 - 15:46
I have been trying to install a virtual network driver with DifxApi version 2.01 with no success. I contacted Microsoft and they told me that it currently doesn't work with some virtual drivers.
Posted 28 January 2008 - 22:10
To my knowledge the DIFx's latest version is 2.01. Is there any new version release? If ther is, please tell me where I can install it from. I wish it is able to install the virtual device driver.
Posted 30 January 2008 - 16:59
According to http://msdn2.microso...y/ms791098.aspx the current version is 2.1. I guess that's the same version as the 2.01 that you mentioned, but I don't know for sure.
Posted 31 January 2008 - 16:06
You should note that DIFx does only support installing (signed) Plug and Play (PnP) function drivers and (signed) class filter drivers.
For detailed info, please refer to DIFx Driver Package Requirements.
