hi there,
I run into a wall, when i try to launch the installed app itself at the end of setup. [Basic MSI, don't want IS Script]
I tried CA with any kind of setting combination, but failed after failed.
who has experience on this issue?
pls guide me through?
Thx
spj
, Aug 27 2003 23:37
Posted 28 August 2003 - 11:59
Can you post the settings of your CA, and the symptoms of the error (do you get an error message? What's in the log?)
Posted 28 August 2003 - 18:28
Hi there,
I already tried any settings. failed. (it works for launching Notepad.exe).
eg.
working dir: INSTALLDIR
file: MYapp.exe (note: the setup is for myapp.exe installation)
return processing: syn(check)
in-script execution: deferred
install exec sequence: after schedule reboot
failed.
I don't know how to configure these settings properly.
who can help me out.
eg.
failed.
Posted 29 August 2003 - 22:01
Why not make it immediate and after InstallFinalize?
Also if your setup requires a rebot you will have to boot before you can run your exe
