I have problem to propose to the end user the choice between 3 configuration type:
- Configuration1: InstallLevel = 10
- Configuration 2 : InstallLevel = 20
- Configuration 1 + configuration 2
I don't have any problem to install the configuration 1 and the configuration 1 + Configuration 2 but
How to install only the configuration 2 without install the Configuration1?
The only solution I have found is to create a general setup.exe who launch one of three configuration.
Do you have a another solution to propose me?
Configure Setup Type and Install Level
Lionel
, Apr 15 2003 10:20
Posted 15 April 2003 - 10:27
Use the Remove control event to deselect Configuration 1 to get Configuration 2 only.
