i have installed a program in WinXP as Administrator.
Now i want to do a deinstall before an installation. The installation of the new programversion is run as "Hauptbenutzer" (or Poweruser?) .
The problem is, that the setup.exe of the orl version, called with -uninstall, will always start the installation prozess and not the uninstall prozess.
Why?
When i run the setup.exe as Admin i can deinstall the program.
How can i find out if a program has to be deinstalled with Admin rights?
Ciao
Tulip001
Problem with uninstall in WinXP
tulip001
, Dec 10 2003 10:57
Posted 10 December 2003 - 17:32
All IS setups require Administrator privileges to both install & uninstall.
To better enforce this you can add checks such as the following to OnBegin:
| function CheckAdmin() NUMBER nResult; STRING szMsg; begin nResult = Is(USER_ADMINISTRATOR,""); if (nResult = FALSE) then szMsg = "This install requires Administrator privileges.\n" + "Please login with such rights and try again."; Msg(szMsg, SEVERE); abort; endif; end; |
