I've a question about the button you see within the Add/Remove control panel when you select an installed product.
When our product is installed, we have a button with the text "Change/Remove". Some products have two separate buttons(Change AND Remove) and some other products have only the Remove-button.
Is it possible that you define which button(s) are showed and which text needs to become on the buttons???
Is this a certain registry entry???
Thanks in advance for your help.
Christoph.
Button within Add/Remove Control Panel
Christoph
, Nov 21 2002 09:12
Posted 21 November 2002 - 19:52
i believe that these buttons are controlled by the ARPNOREMOVE and ARPNOREPAIR properties...
i would suspect that the msi that has only the remove button will have the entry ARPNOREPAIR in HKLM\Software\Microsoft\Windows\CurrentVersion\UnInstall\...
entry for the MSI
entry for the MSI
Posted 22 November 2002 - 15:10
I added the regentry "NoModify" with as value '1'. As a result I see only the remove-button within the control panel so it seems to work. I tried this on WinXP. When I try this solution on Win2K, nothing changes.
Has anyone encounter the same problem???
Posted 26 November 2002 - 22:06
To fully support this you may have to use Windows Installer (MSI) technology instead of a legacy tool like Professional 5 (you could upgrade to InstallShield Developer 8)
