Hi Everyone,
Is it possible to change the IP Address through the Install? For example, if the target's computer IP Address is 192.168.1.2 and it should be 192.168.1.3, can I do this through the install script?
Mike Goldweber
changing a computer's IP Address
halciber
, Nov 28 2007 20:06
Posted 28 November 2007 - 20:38
I couldn't find anything in DevStudio to change the IP Address; however I did find a command line alternative to this. I used the following:
netsh interface ip set address name="Local Area Network" static 192.168.1.2 255.255.255.0 192.168.1.1 1
where,
192.168.1.2 = new IP address
255.255.255.0 = Subnet mask
192.168.1.1 = default gateway
1 = metric number
Mike
where,
1 = metric number
Mike
Posted 29 November 2007 - 13:07
You could try to execute the following windows scripting host code from IS or to "import" it to script.
If you need help with that just say...
strComputer = "." Set objWMIService = GetObject("winmgmts:" _ & "{impersonationLevel=impersonate}!\\" & strComputer & "\root\cimv2") Set colNetAdapters = objWMIService.ExecQuery _ ("Select * from Win32_NetworkAdapterConfiguration where IPEnabled=TRUE") strIPAddress = Array("192.168.1.2") strSubnetMask = Array("255.255.255.0") strGateway = Array("192.168.1.1") strGatewayMetric = Array(1) For Each objNetAdapter in colNetAdapters errEnable = objNetAdapter.EnableStatic(strIPAddress, strSubnetMask) errGateways = objNetAdapter.SetGateways(strGateway, strGatewaymetric) // arrDNSServers = Array("xxx.xxx.xxx.xx") // objNetAdapter.SetDNSServerSearchOrder(arrDNSServers) If errEnable = 0 Then WScript.Echo "The IP address has been changed." Else WScript.Echo "The IP address could not be changed." End If Next |
