Icon on Add/Remove Programs
in_install
, Mar 03 2006 15:53
Posted 03 March 2006 - 15:53
The folder icon is displayed for the product installed in Add/Remove Programs.
I need to diplay the icon, what the exe(od.exe) contains.
For this, in MSI project, in Add/Remove Programs view for Display Icon, I entered following value ,
<ISProjectDataFolder>\files\od.exe
Let me know how to get the correct output.
Posted 06 March 2006 - 16:58
If this is a per-user install then what you see is a known bug in Windows.
Posted 07 March 2006 - 06:09
is it a bug in MS installshield ?? I m using version 10.0.
I found some more products installed on my system, installed by MSI project installer. For them, there is icon on ADD/Remove programs. How that is done ??
Edited by in_install, 07 March 2006 - 15:06.
Posted 07 March 2006 - 15:24
If you see corect icon only on machine where this install created, then use INSTALLDIR instead of ISProjectDataFolder.
Posted 07 March 2006 - 15:58
I tried following:
INSTALLDIR\OD.exe
[INSTALLDIR]\OD.exe
[INSTALLDIR]OD.exe
But none is working. The error encountered during build is :
The source file ...OD.exe for Icon ARPPRODUCTION.exe does not exist.
INSTALLDIR\OD.exe
[INSTALLDIR]\OD.exe
[INSTALLDIR]OD.exe
Posted 07 March 2006 - 19:01
I'm not following you here but there is a known bug in Microsoft Windows (not in InstallShield from Macrovision) that diaplays a folder icon instead of the product icon if the setup is installed per-user. Does it display the correct icon if you install per-machine (ALLUSERS=1)?
