I am using Installed Shield Professional 11.0.
I added a custom action to execute a batch file. This batch file required some parameters (or command line arguments).
How can I pass command line arguments to this batch file silently?
Yogesh
Call batch file with parameters in Custom Actions
yogesh.gupta
, May 03 2012 02:39
Posted 09 May 2012 - 11:00
Say I have a batch fle named build.bat.
I will do something like this:
build.bat release
OR
build.bat debug
Assuming that the build.bat actually compiles some code, I can use the parameters passed(release or debug) to compile code in the desired configuration.
Using LaunchAppandWait function in the Installscript, you can pass the commandline parameters as an argument.
build.bat release
OR
build.bat debug
