Hello
I am asking for assistance with a problem. I have an ins file, Its for the internet connection wizard setup. I want to put the dialup.ins file on a CD and have autorun when the CD is put in the drive!
The dialup.ins file works on a floppy,It works from the hard drive, but i cant seem to get it to open from a CD
I tried making autrun files but keep getting a error message that states the internet connection wizard is unable to process the file!
as i stated ealier the file opens from the hard drive,floppy disk but not the cd.
any help would be apreciated
thank you
Joe
Autorun an ins file
Joe Ferdinando
, Jun 01 2003 06:46
Posted 01 June 2003 - 06:46
Visit ferdiworks.biz for your dialup internet needs
http://ferdiworks.biz
want to be your own AOL
http://ferdiworks.biz/beyourownaol.php
Posted 02 June 2003 - 06:34
I think the only programs autorun will open are .exe, and .com.
You create a .exe file that will run a ShellExec and open the dialin.ins
Posted 07 December 2003 - 03:11
I am pretty sure luke_s suggestion will work fine. I have never tried with .ins files, but sometimes I call explorer.exe with a file I want opened as command line. This normally correctly invokes the application that is set up to handle that file type. But either way, an EXE file that runs ShellExecute would be the better solution.
Posted 08 December 2003 - 11:08
.ins files run with ISIGNUP.EXE, so try
| [AutoRun] OPEN=isignup.exe dialup.ins ICON= ... |
instead.
Gruß / regards
Thomas
Thomas
