Dear All
In dialog InstallChangeFolder there is a directrory combo for look in.
I reduced it width and moved it little up & down on the dialog form. After doing so I found it stoped expanding while run time to show all available folder and drive in the installer machine.
I removed the control and added it again with property _BrowseProperty, but still it is having problem of expading and showing the foldders at run time. Please suggest to solve the problem
Sanjoy
Control Directory Combo
sanjoygr
, Mar 29 2006 11:11
Posted 30 March 2006 - 09:09
Make sure the Height property of the combo box is set to a high value (default is 80 but you can as well try 800)
