Can someone explain how version control works in IS Pro 7. I have an existing install (it is already deployed) that uses Pro 5. I would like to install a new version of this install that will be concurrently installed with the old version. These two versions will share environment variables and a few registry keys. They also run as services and cannot both be running simultaneously. Currently, the new install is being written in Pro 6.
The documentation for Pro 7 discusses having multiple installs running concurrently and discusses being able to handle multiple versions. Will upgrading address my problem, or am I being too optimistic? Does anyone have any other suggestions?
Regarding Version Control
thebert99
, Mar 25 2003 18:33
Posted 22 April 2003 - 19:11
You can develop an installer to uprade the old version but then they both will not be installed.
You can develop it as a new product (change the product ID) so that both can be installed but you will need to write custom action code to shut the older version down so both services don't run at the same time.
