Hello!
I want to create a msi-setup to deploy our ClickOnce Files to the server of our customers. What I want ist the following:
First-Install:
- Dialog to write the Install-Path in
- Copy the files to a directory/Web-Dir or FTP-Dir
- Dialog with Textboxes (Servername etc.)
- Edit an XML-File
- Dialog to choose the Certification-File
- Enter Password for that File
- Resign the Application-Manifest and the Deployment-Manifest of the ClickOnceFiles with this Certification (I've created a custom-action for that, or I could use the command-line tool mage.exe for this)
Update-Install:
- Detect the previous Installation
- Read XML-File from the detected install-path
- Copy the new Files
What are your recommendations to do this...is visual studio (2005) able to do this all or should I better use Wise, InstallShield or another product?
Thanks for your advice!
Kind regards,
Peter Wyss
Recommendations Wise/InstallShield/VisualStudio
blood_on_ice
, Mar 10 2008 18:01
Posted 11 March 2008 - 14:01
I don't think VS has a dialog editor for installs, does it? I can't recall - it's been a while...
In any event, you'll find the tools from the two main protaganists - Wise and InstallShield - have MSI-authoring functionality way above that available in the VS editor. I've looked at the other tools (some freeware) out of curiousity but always end up returning to Wise/InstallShield.
