Hi i got problems with setting 'parameters' for my CA.
i got CA
Action: callDllTest
Type: 1
Source: dllBinFile
Target: TestFunction
also i got CA
Action: callDllTest.SetParameters
Type: 51
Source: callDllTest
Target: [ProductVersion];[ProductName]
i got button in dialog and when i push it i call 1st callDllTest.SetParameters and after that callDllTest.
In TestFunction i call MsiGetProperty with "CusomActionData" but it returns null. does any one know why its null?
Thanks for any tips.
CustomActionData
joker_pl
, Nov 10 2005 16:00
Posted 11 November 2005 - 09:46
I think, that you call the second ca at the client process. The propery CustomActionData is valid only, in server process. In other words. You must implement this action between InstallInitalize and InstallFinalize. Further, you must specify this action as deferred. Add 1024 or 3072 to the ca type.
- Andreas
- Andreas
Andreas Kerl
Inside Windows Installer 4.5
ISBN 3-86645-431-7
Posted 11 November 2005 - 10:03
Otherwise (if your custom action is not deferred, betwen InstallInitialize and InstallFinalize) it has direct access to the properties.
Posted 14 November 2005 - 09:38
thanks a lot for your help, but when i add 1024 or 3072 to action 51 i get 2723 error.
and what bout calling between InstallInitialize and InstallFinalize - i need to call this CA from UI.
Edited by joker_pl, 14 November 2005 - 10:04.
Posted 14 November 2005 - 10:38
Don't add 1024 or 3072 to the CA Type 51. Add the values to the executing action, in your case type 1. The property CustomActionData is only available between InstallInitialze and InstallFinalize. If you need the CA in UISequence, you've full access to all installer properties. If you need the property TARGETDIR e.g.
, you can get this property with Session.Property["TARGETDIR"] or MsiGetProperty().
Andreas Kerl
ISBN 3-86645-431-7
