patch problem
asrinivas
, Aug 03 2007 09:59
11 replies to this topic
Posted 03 August 2007 - 09:59
we have prepared patches for our application , but it is not replacing the .DLLS ,.OCX etc if we dont change the component version.
does widows installer consider only the component version for replacing or any other attributes like last modified date ..etc...
this is the problem we are facing.... please help us!
Regards,
A.Srinivas
Regards,
A.Srinivas
Posted 07 August 2007 - 14:47
A component doesn't have a version. A DLL or OCX file has a version. All DLL and OCX files should be the key file of their respective component. Overwriting depends on the version of these files.
Posted 10 August 2007 - 15:56
For every individual file, you may set the "Always Overwrite" flag in the file properties (NOT for dynamic linked files). This would ignore the file version.
Posted 13 August 2007 - 05:47
| QUOTE (m.nouryan @ 2007-08-10 15:56) |
| For every individual file, you may set the "Always Overwrite" flag in the file properties (NOT for dynamic linked files). This would ignore the file version. |
we have set always overwrite property also.but it is not replacing.
what might be the problem.
we are not changing the version of the file.(DLL,OCX..) If we change that , automaticallly it is replacing
regards,
asrinivas
Posted 13 August 2007 - 14:12
I’ve had that problem with “Quick Patch”, regular patches work fine for me. Which one are you using?
Posted 14 August 2007 - 09:36
thank you very much for your response
we are using quick patch project.......accroding to our requirment we have to go for that only...
regards,
A.Srinivas
regards,
A.Srinivas
Posted 14 August 2007 - 10:12
regards,
A.Srinivas
regards,
A.Srinivas
Posted 14 August 2007 - 15:49
I had to switch to regular patches because of this; if you find the solution please post it here!
Good luck
Good luck
Posted 27 August 2007 - 13:52
I'm in the same boat here. I have an MSI I originally created using Visual Studio 2005. I created a Quick Patch InstallShield 11.5 project, because I want to just patch the EXE of my install. I specify the file to upgrade, give it the path to the new one, and just to be safe checked the box to always overwrite the file (although I've tried it without too). But when I install the patch, I still have the old executable. I even tried removing the EXE and installing the patch, and I get the old EXE. It appears that the patch has the old version of the file (1.0.0.0) even though the patch setup says the new version is 1.0.0.1. Any ideas as to what I'm doing wrong (if anything)?
Posted 29 August 2007 - 10:07
| QUOTE (Mazrim5 @ 2007-08-27 13:52) |
| I'm in the same boat here. I have an MSI I originally created using Visual Studio 2005. I created a Quick Patch InstallShield 11.5 project, because I want to just patch the EXE of my install. I specify the file to upgrade, give it the path to the new one, and just to be safe checked the box to always overwrite the file (although I've tried it without too). But when I install the patch, I still have the old executable. I even tried removing the EXE and installing the patch, and I get the old EXE. It appears that the patch has the old version of the file (1.0.0.0) even though the patch setup says the new version is 1.0.0.1. Any ideas as to what I'm doing wrong (if anything)? |
as far as my knowledge , this cannot be solved with quck patch project.only the way to create a patch for this is choosing patch design view.with quich patch , if the version no are equal for old and new component , it wont replace.
go to the components view and add the new component and righclick in the files view and go to properties and increment the version no in "override version no" now prepare the full build and then prepare patch by choosing the patch design view, dfnty it will work.
regards,
A.Srinivas.
Posted 29 August 2007 - 14:15
Doesn't that essentially mean that a Quick Patch is pointless? Isn't a patch supposed to be used to patch/update/replace one or more (but probably not all) parts of an installation?
Basically here's my situation (maybe someone can tell me the best way to handle this): I'm a developer. Once I create an application (typically in VS2005 using C#), I have to create an MSI and give that MSI to our infrastucture group to install on a production server. When they do this, they typically have to modify the config file to put some username/password in (usually for Oracle) that I'm not allowed to have in production. If I need to do an upgrade, I don't want them to have to copy off the config file, uninstall the old version, install the new version and put the config file back in place (so that they don't have to put that username/password back into the config file). I'd rather create a "patch" that just replaces the EXE or DLL or whatever needs replaced, and not touch the config file. I don't see any way to do a patch with the VS2005 setup projects. I tried to create the initial setup project as an InstallShield project inside VS2005, but when I try to add the project output to it, VS2005 crashes. I thought the Quick Patch was my answer, since it let me choose the original MSI, and then let me choose what file to patch and where the new version is. I don't understand why the interface to the Quick Patch does all of that (it shows the old file version and the new file version, with a message that says the new file will be the one installed when the patch is done), yet the patch doesn't install the new version. To me, that sounds like a bug in Quick Patch.
Posted 03 September 2007 - 14:37
| we are not changing the version of the file.(DLL,OCX..) If we change that , automaticallly it is replacing |
I think this is the problem. If the file is newer and therefore needs to be updated, it should also have a higher version number. Having tow different versions of a file with the same version number will confuse Windows Installer (and the developers and testers, too).
