Hello,
I have problem with my setup program under Windows 95. Windows 95 denied to accept the dll files with the same name in my setup packet to be overwritten !!!
What shall I do
Thanks.
How to overwrite the DLLs in Windows 95 ?
DocLuan
, May 23 2002 10:46
Posted 29 July 2002 - 10:05
Maybe, you should try the "potentially locked" set to "Yes" in the corresponding file group (I'm using the German InstallShield, so the property name might be misleading), and use the reboot option after install.
doing this, InstallShield makes a copy of your DLL with extension ".1", and the Reboot procedure will replace the files
