Is it possible to add or remove a file to an installation inside installscript code? For example, add a file to the installation only if some test returns a true value.
thanks in advance
Add or remove files in run-time
oscarin
, Jun 05 2006 14:39
Posted 06 June 2006 - 08:09
You need to add the file to the install package at build time, but you can decided at install time whether the file will be copied to the target machine or not.
